ptrondsen29's avatar
ptrondsen29
Orbi RBR20 Backhaul Ethernet/Switch
Hello All, I'm having a problem with my Netgear Orbi.
Here's the setup Netgear RBR20, with 2 satellites.
I'm using the router with FIOS, and not using using a FIOS modem, direct ethernet from the ONT to the Netgear Orbi router.
One satellite is just connected over WIFI, and then the second one is connected via a 50 foot ethernet cable into my office.
This worked fine for a while and suddenly stopped working.
I tried using an ethernet switch, connected to the satellite and that stopped working too.
I took the satellite off of ethernet, and just connected the switch, and after a while stopped working as well.
So, basically, running a 50 foot ethernet cable to my office only works with one device, when I add additional devices, either through a satellite or ethernet switch, the internet comes to a crashing halt after a while.
Any configuration changes would be helpful, is this an issue with NAT filtering??
Thanks,
Pete
  • FURRYe38's avatar
    CAT6 would be recommended and to use ALL cat6 cabling.
    IF the connection works with out the switch then seem to have problems with the switch, then the switch would be a cause of the problem. I see this model switch has green ethernet features, (Energy Efficient Ethernet) 802.3az standard. Something that causes problems with Orbi Systems.
