Username000
Apr 27, 2020Aspirant
Can't get VLAN's working across uplink between GS110EMX switches
We have two GS110EMX switches, one each at opposite ends of a satellite office, using port 10 to provide a 10Gbe uplink between the two. On switch number 1, Port 9 is used for services by a 10Gbe NI...
- Apr 28, 2020
Well, it's almost always somethign stupid and obvious. In the process of setting up a second client per your suggestion, I discovered that the uplink and 10G workstation connections got swapped so there is no surprise as to why there was no VLAN 50 tagged traffic was not passing. Argh. Thanks for the assist, at least it made me re-check something that helped me figure it out.
schumaku
Apr 27, 2020Guru - Experienced User
This is your VLAN 50 :
NAS <-> #9 VLAN 50 [U]ntagged, PVID 50, VLAN 1 [ ]nomember <-> #10 Trunk with VLAN ID 50 [T]agged <-trunk-link-> #10 Trunk with VLAN ID 50 [T]agged <-> #9 VLAN 50 [U]ntagged, PVID 50, VLAN 1 [ ]nomember <-> Video Workstation
This is your VLAN 1:
Firewall, others, ... <-> #1..#8 VLAN 1 [U]ntagged, PVID 1, VLAN 50 [ ]nomember <-> #10 Trunk with VLAN ID 1 [T]agged <-trunk-link-> #10 Trunk with VLAN ID 1 [T]agged <-> #1..9 VLAN 1 [U]ntagged, PVID 1, VLAN 50 [ ]nomember <-> others
Username000
Yeah I have a lot of stacked M4300's etc at other sites, these much smaller switches leave a lot to be desired. I use separate physical interfaces on the NAS and ASA for management and I don't want to get into that aspect of the setup as it is not relevant to the issue at hand except to say that they exist.
In the attached graphic, switch 1 is on top, switch 2 is on the bottom.
If I plug in a laptop configured for VLAN 50 to port 5 on Switch 2 and ping a device on port 2 Switch 1 and get no response. If I unplug the laptop with it still attempting to ping and carry it to switch 1, then plug into port 5 on switch 1, it gets responses.
- schumakuApr 28, 2020Guru - Experienced User
Leaving alone that I have zero trust in many NIC drivers in their basic features - the amount of problems we see popping up on major OS and distros is overwhelming (problems with basic speed negotiation, flaky performance, not honouring config settings, ...) regardless if we talk Linux or Microsoft validated drivers - I can't see why one should use tagging in plain network interfaces ... configure the port to the VLAN untagged & the same PIVD.
To understand the effective issue, there are simply to many unknown variables. Trying to connect from a client interface supposedly tagging (bad policy for what should be a flat interface IMHO), connected to an switch interface connecting into two VLAN (one properly untagged/PVIDed for 1, one tagged for 50), through a trunk (which looks OK, having a trunk fully tagged is my preference but for simplicity one might do the primary VLAN untagged), to a destination port having both VLANs 1 and 50 tagged connecting to an unknown device where obviously both VLANs just be tagged.
Consider to restart your test with plain simple and clear untagged test devices run on an untagged/PVIDed port into the VLAN 50. Can't see why this should not work and allow connectivity through the trunk (both on the port #10).
That's all yet another community member can do for you.
- Username000Apr 28, 2020Aspirant
