Becketo
Jan 04, 2021Follower
Can't login to ProSafe after firmware update 2.6.0.48
Hello Tech, 1. I received an email to update my switch firmware. 2. I installed the firmware 2.6.0.48 with no problem. I did not record the previous firmware number. 3. I opened my ProSafe Plus...
DaneA
Jan 19, 2021NETGEAR Employee Retired
Welcome to the community! :)
What is the current version of the ProSAFE Plus Utility you are using? If you are not using the latest version which is ProSAFE Plus Configuration Utility v2.7.8, you can download it here then install it to your PC/laptop.
DaneA
NETGEAR Community Team
spuch
Feb 28, 2021Guide
In the German forum the same problem is discussed. The 8-Port GS108Ev3 and the 16-Port GS116Ev2 are facing this problem. While local access to the Webgui from the same network seems to work at least mostly the access via VPN fails. So far there seems to be a problem with the MTU. If set to 1500 it is working and if smaller e.g. via VPN over the Internet the Webui is not reachable.
Possible work arounds: For GS108Ev3 a downgrade using the Prosafe Plus-Configurationutility 2.7.8 to firmware V2.06.10 and for GS116Ev2 to firmware V2.6.0.43
Unfortunately if a switch is not reachable with the Utility a downgrde is not possible. I'm facing this problem, too for one of my GS116Ev2. While i succeeded in downgrading my two GS108Ev3 to the preformer firmware version I'm not able to do the same for my GS116Ev3 on firmware V2.6.0.48. The switch is not even listed in the Utility. Obviously the last set fo updates provided from Netgear are not a big deal...
