grasshopper1969
Oct 27, 2021Apprentice
Slowdown of data JGS516PE after firmware 2.6.0.48
Hi, just wondered if anyone else experiencing a slowdown over time after updading to firmware 2.6.0.48 on this unit, connection on some ports say connected at 1000 but when I speed test that port connection only getting 100 out of it. Do a reboot & that port jumps back to 1000. Could see this happening with file transfers & when plex being used connection would drop to player.
thanks
Hi Dana, after last reboot its been running fine so far, must have just needed another reboot after firmware update to settle down.
- DaneANETGEAR Employee Retired
Let us try this. Perform a factory reset on your JGS516PE then reconfigure the settings from scratch. Observe if the same problem will occur.
DaneA
NETGEAR Community Team
- grasshopper1969Apprentice
