Retired_Member
Jun 27, 2022Chat support not available
Hello, according to my account, there should be lifetime chat support for my registered switch. But I cannot open a chat, it always says "Chat is busy, please try again later". What kind of s...
Jun 27, 2022Guru - Experienced User
Looks like its not available on mine right now if I try to chat on one of my supported devices either.
it could be:
- its only available during certain hours (would be nice to be posted)
- its truly busy and backed up so isn't available
- its actually having issues and not working
Tough to know which it is.
- Retired_MemberJul 01, 2022
No operating hours are mentioned. And I tried to access the chat a various days and times. Especially on weekdays between 9am and 3pm one would expect that it is operating ...
It simply always says: Chat busy, please try again later.
- schumakuJul 02, 2022Guru - Experienced User
There are much better and easier to deal with support options available, certainly in the first three months. Head to https://my.netgear.com/ then select the product registered using [View Product].
As the firmware update caused the device non-workable, you can always use the [request hardware support]
Using [Email] or [Request Hardware Support] does offer the ability to add some description, add some attachment, ... Once filed, the cse is tracked, there is no need to query the "what is wrong" questions ... typically much more time consuming. Once support has reviewed, you get a ticket number assigned, receive the information on how you can get in contact to a human (typically through a phone number) in a time windows better for you. The support person is prepared what is coming with the call, and can react much better.
