adamw-ms
Jul 18, 2022Aspirant
config export/import GS724T v3 -> v4
As mentioned in my earlier thread:
https://community.netgear.com/t5/Plus-and-Smart-Switches-Forum/config-export-import-GS724T-v2-gt-v4/m-p/2240536#M21211
Is config exported from v3 expected to fully work once imported to v4?
Unfortunately, it is the same with all versions of GS724T the config files are not compatible due to the same reason.
HTH
1 Reply
