Budgie4's avatar
Budgie4
Tutor
Sep 12, 2021
Configure vlan security Netgear GS728TPPv2 M4100-24PoE+
I have run out of ports on my UTM which defines each subnet.  Is it possible to have two different subnets share a vLan. My problem is that each subnet has several devices which have connections to ...
  • Budgie4's avatar
    Budgie4
    Sep 13, 2021
    Hi Schumaku,
    OK, I take the point and of course can all be done on UTM.  It was just me being strange and wanting to do all the Vlan work on the switch rather than UTM and looking at rather neat solution which might have improved my knowledge base.  (I know, it is still rather low!).
    Will take the soft option and many thanks for your informative reply.
    If I get stuck I shall start a new thread so saying thanks again.
    Alastair
ProSupport for Business
