SamWeng's avatar
SamWeng
Follower
Oct 23, 2023
GS728TPPv2 how to trunking SonicWALL VLAN
HI Support
we have the remote station use SonicWALL TZ500 + GS728TPPv2 could switch setup on customer site.
We all set up on SonicWALL TZ500, the details are:
LAN X0 Prot IP: 10.255.255.254, Mask:255.255.255.0, DHCP: 10.255.255.100 to 200
SonicWALL TZ500 X0 port connect to Switch 24 Port, and we connect one WAX610 Wifi provide to customer connect VLAN network to use.
WAX610 WiFi equipment connect to switch 1 port.
VLAN Port: 10.255.100.254, Mask:255.255.255.0, VLAN DHCP: 10.255.100.100 to 200
The problem now is that I cannot let customers obtain the IP address of the VLAN. How do I set up a VLAN trunk on the switch?
  • SamWeng wrote:
    HI Support
    Hi Sam,
    This is the Netgear Community, not Netgear Support here.
    Switching > VLAN > Advanced > VLAN Membership
    Select the VLAN you want on the trunk (port or LAG), and mark these as [T]agged.
    -Kurt
1 Reply
  • schumaku's avatar
    schumaku
    SamWeng wrote:
    HI Support
    Hi Sam,
    -Kurt
ProSupport for Business
