jebusfreek666
Jan 29, 2020Aspirant
Connect GS728TPP SFP to GS752TX SFP+
As the subject says, I am looking to connect these 2 switches via their SFP and SFP+ ports for uplink. I would like to run 2 cables between them, very short distance, about 6 inches. I realize this w...
- Jan 29, 2020
So I need one of each of these modules to make these 2 switches connect? What cable would I use between them
You will only need either the AGM731F or AGM732F. You can use any 1Gbps Direct Attach Cable.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Jan 29, 2020NETGEAR Employee Retired
Welcome to the community! :)
The SFP modules that are compatible to both GS728TPP and GS752TX are the AGM731F and AGM732F. Kindly refer below:
DaneA
DaneA
DaneA
