hoff081
May 02, 2022Aspirant
Connect two Switches
Hello, I have a GS724tpp switch that is working great. On one of the runs I have a small dumb hub that connects 3 devices to the network. When this connection is connected the three devices do not h...
DaneA
May 04, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Was everything working fine before? If yes, are there any changes made on the settings of the GS724TPP or any changes on your network setup?
Is the small dumb hub directly connected to the GS724TPP?
Are you using the GS724TPP just like an unmanaged switch?
Kindly post an image of your network diagram. Make it very detailed as possible.
DaneA
NETGEAR Community Team
- hoff081May 04, 2022Aspirant
Hello DaneA,
The switch they had in place stopped working and they replaced it with the GS724TPP.
Yes it is.
Yes they are.
Pretty simple network and they not have a diagram of it. Flat network with about 18 workstations\network devices. One office has a run into it with the dumb hub with a computer and a time clock plugged into it. With the hub in place neither device has has network connectivity, by pass the hub and the device connected has connectivity.
Thank you,
Tom
