andycritt's avatar
andycritt
Switch Dropping Internet Connection
Bought this GS116Ev2 last November as I needed more ports but have only just got arounfd to installing it. The switch keeps dropping all the connections. Having read other posts, just updated the firmware today and reset more times than i can remember but still no joy. Contacting Netgear directly seems like I have to pay as the switch is more than 90 days old...?! Gone back to my old 5 port switch as at least this works.
  • Hi,
    Its not the switch thats at fault, apparently its the Virgin Hub 3 that's the issue. I put my Hub 3 into modem mode and bought an inexpensive wifi router (TP-Link Archer C50 AC120) and this works absolutely fine with the switch. I dont know whether its a compatability issue between the Hub 3 and the switch or just that the Hub 3 cannot support a 16 port switch.
    Downside is that now my wifi is slow as despite its faults the wifi from the Hub 3 was fast and I dont really want to spend more money on a faster router, kind of hoping that the virgin Hub 4 will be available soon and that it will work with the switch.
    • andycritt's avatar
      andycritt
      Thanks for the reply. I have a batch of cat 6 cables and swapped them around but no change. Managed to submit a case to Netgear and after eventually getting through on the phone they offered to swap out the switch FOC within a minute of explaining the situation to them so excellent service there. As for on line chat all I got was “past 90 days, pay for a service” kind of message.
      Let’s hope the new switch works.
        andycritt
        Brand New GS116Ev2 arrived today, plugged in and all worked, for 5 minutes then everything goes offline again..!
        Virgin Super Hub 3 connected into Port 1
        Ports 2,4 connected to V6 box and Amplifier,
        Ports 5-11 around the house to wall sockets
        Port 15 to Hive Hub
        Port 16 to Synology NAS
        Looking at the setup instructions it only needs one ethernet cable into the switch from the hub and into any port?
        Plug my old 5 Port GS105E in and everything works fine (whats connected).
        Confused..!
ProSupport for Business
