hoff081
May 02, 2022Aspirant
Connect two Switches
Hello, I have a GS724tpp switch that is working great. On one of the runs I have a small dumb hub that connects 3 devices to the network. When this connection is connected the three devices do not h...
hoff081
May 04, 2022Aspirant
Also,
The switch is running the config that it came with out of the box.
Tom
DaneA
May 05, 2022NETGEAR Employee Retired
@hoff081,
Just to verify, there is connectivity through the GS724TPP and it works fine. But when this small dumb hub is directly connected to the GS724TPP, the devices connected to the small dumb hub, does not have connectivity. Am I right?
What is the behavior of the corresponding port LED on the GS724TPP where the small dumb hub is directly connected?
What is the brand/model of the small dumb hub?
Is there a router in the network? If yes, is it directly connected to the GS724TPP?
DaneA
NETGEAR Community Team
