iamSteve
Feb 19, 2020Guide
Connection between 2 switches
I own several netgear switches but have a question relating to a link between:- GS724Tv3 - 24 Port Gigabit Pro Safe GSS108EPP – 8-Port Gigabit Ethernet PoE+ Smart Managed Plus Click Switch I cu...
- Feb 19, 2020
Hi Steve,
Yes, you can: Create a Static LAG (Link Aggregation Group) on both switches.
Note: It has to be static because of the 116EPP does not support dynamic/LACP. Don't connect the second connection before both ends are configured - in case something goes bullocks, you can always disconnect the cable again.-Kurt
schumaku
Feb 19, 2020Guru - Experienced User
Hi Steve,
-Kurt
