z_ae19844
Sep 24, 2023Follower
Connectivity and bandwidth re: Pro GS108T-300UKS managed switch
Hi all, Trying to help a customer get connected up. They are using a Cityfibre FTTP connection via Zen Internet, and they are using a Google Mesh router. Unfortunately, the router is not compatib...
schumaku
Sep 25, 2023Guru - Experienced User
z_ae19844 wrote:
Is the switch rated to a gigabit in terms of network throughput, or less?
Of course, these switches are providing fully line speed, the switch fabric does provide a 16 Gbps line-rate, covering bi-directional wire speed on all ports.
Performance Specifications GS108Tv3
1G Copper latency (µsec)
(64-byte; 1518-byte; 9216-byte frames)
64-byte: 3.847 µsec
1518-bye: 4.047 µsec
9216-byte: 3.784 µsec
