tmarsh12345
Sep 24, 2018Tutor
connectivity issues
Can't connect to my GS108Ev3 either by web or Pro safe utility. I get not in the same subnet error. What can I do?
- Sep 24, 2018
Thanks for the quick reply. I came across another post and removed the ethernet cable, powered off the switch, reconnected cable and power and voila!
schumaku
Sep 24, 2018Guru - Experienced User
Temporarily configure a network interface into the same TCP/IP subnet as the GS108Ev3 currently is, different address, same subnet mask, default gateway and DNA to any random number, e.g. .1.
If your network has a working DHCP server, you can enable the DHCP client on the switch, otherwise manually configue it into a defined (and obviously free) IP address.
tmarsh12345
Sep 24, 2018Tutor
- smith987Sep 24, 2018Aspirant
I have recently brought a new Netgear Nighthawk X10 AD7200 Smart WiFi Router and tried to connect it with my HP laptop but unfortunately, it is not connecting, I thought this is the laptop issue that is why I also consulted with hp support Canada but they told me my laptop is absolutely perfect then tell me what is the exact issue in my router and how it would be solved?
