tmarsh12345's avatar
Sep 24, 2018
connectivity issues
Can't connect to  my GS108Ev3 either by web or Pro safe utility.  I get not in the same subnet error.  What can I do?
  • tmarsh12345's avatar
    tmarsh12345
    Sep 24, 2018
    Thanks for the quick reply.  I came across another post and removed the ethernet cable, powered off the switch, reconnected cable and power and voila!
ProSupport for Business
