Etz's avatar
Etz
Couple of questions about GS110EMX
1) Does GS110EMX support SNMP? 2) What does Web Managed mean, Web Interface or only restricted to config utility?
  • XavierLL's avatar
    May 02, 2018
    HI Etz
    The GS110EMX doesn´t support SNMP, about the management it´s web managed so you can configure using your browser . Moreover you also can configure it using the Prosafe Plus utility if you prefer.
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
