eclcm
Jan 28, 2022Aspirant
Create Port Based VLAN
Hello everybody, I am trying to create something like port based vlan on a gs748t since it does not seem to support port based vlans. What I want to achieve is to have multiple port groups isolated f...
eclcm
There is also no port forwarding involved, I directly connected a cable from the router to the port. See this more as a propetarian DMZ, g3 to g8 as a standalone switch.
g3 to g8 are not part of any other LAN. I can not select untagged only since this option does not exist.
schumaku
Jan 28, 2022Guru - Experienced User
Yes, this is what is configured now.
OK, this makes up a dedicated network (except of STP/RSTP which does span al VLANs)
Correct - ignore my bad advise, sorry please.
