bigdaveXL
Jan 28, 2020Tutor
Create Vlan on GS724Tv4
I currently have two VLans that are both set with the same IP addresses (all 192.168.0.x) I have no duplicate IP addresses within this as on Vlan A the DHCP is set to give IP's 192.168.0.2-50 and on ...
- Jan 30, 2020
Enable VLAN Routing (p.152) , keep the CCTV system on one untagged VLAN port, and then think about either properly limiting the access to the CCTV system, or set-up some ACLs or better IP rules (p.215/216) (that would be a longer story then).
bigdaveXL
Jan 29, 2020Tutor
I have given one of the VLANS a different IP range, I attempted to set this up by tagging the port so it's visible on both Vlans it did not seem to work, I was told by Netgear the device that is plugged into the port (which is our CCTV system) needs to supporting tagging. Surely that's not right is it, I thought to the device it would be seamless?
schumaku
Jan 30, 2020Guru - Experienced User
