CWO2H's avatar
CWO2H
Follower
Dec 07, 2023
Determine if phone is assigned correct VLAN via cli
What command line can I use to determine if a VoIP phone is using the correct VoIP VLAN
  • schumaku's avatar
    Dec 08, 2023
    Lack of any insight, and taking the fact you posted in the Smart Pro Managed Switches community section, here we go:
    Check the MAC address table which does include the port and the VID you can use the
    show mac address-table [mac-address]
    On Smart Switches without the Lite CLI, check Switching > Address Table > Address Table and search by MAC Address:
ProSupport for Business
