Overtkill
Dec 15, 2025Tutor
DHCP assignment issues on RS700 are not fixed
Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings.
Thanks!!
Issue resolved. BitDefender Security suite's firewall has an issue with detecting the network is a Home/Work network, and Public. Forced settings to Home/Work, and had to do this a few times on one rig, due to BD not saving the settings properly. One would think that they'd easily pull that information from Windows on install (c# System.Management "Network Category").
Additionally, it also has a "Stealth Mode" feature, that also has to be turned off.
This resolved the issue on all 3 machines.
I appreciate your help and time. And the same to WarmHelp_NTGR. :)
Thanks!
What brand and model# ISP Modem or ONT do you have?
What DHCP assignement issue are you seeing?
On the RBRs web page?
What devices are you setting up with IP address reservations? IF any?
Any conflicts in IP address between two devcies or more?
Trial FW is for WAN side issues with ONT systems.
Any progress and feedback on this?
My answer is directed solely at the Netgear Rep. on these forums.
Seems like a DHCP issue on the LAN side (Where's the lease time setting for this router??). Every week without fail, PC's will boot up with no Internet access through the RS700, requiring another reboot of each PC. Ethernet on my PC, which has seen this issue, is an Intel i226-V wired adapter on the motherboard. No issues with 2 older Netgear routers tried. RS700 has been updated to current firmware in October (1.0.9.16_2.0.106), reset and reconfigured several times as well. No changes. Adding machines (PC) to a reservation doesn't help. Devices on my LAN are mainly streaming, 2 phones and a tablet, 1 XBox (almost never used) and of course, several hand built PC's. Which are all on reservations at this point. No address conflicts exist at all. I am an admin BTW.
ONT is a Calix, 711, possibly a 712 series. I would have to open the box outside. No issues there either. I have tested connectivity separately with a laptop to the Ethernet cable, and found no issues on that side. Issue remains with the router. Cable also tests good and excellent quality on the link across the wire from my closet to the outside. (Cat-7 Analyzer tested.) PC's tested with another router while being bumped offline, connectivity works when another router (AX12) is dropped into the RS700's place. I used the same configuration on both, and the RS700 started working again after a reboot.
I've had my share of buggy routers from Netgear over the past number of years. The last one would overheat out of the box (AX12), thus failing at random and requiring a secondary fan blowing on the router constantly to keep it cool enough to operate. Same behavior with the replacement I received. So I bought this RS700 to replace the last one, figuring the Flagship model might work as expected. Which still has this issue regardless of the firmware I have tried to date. If this isn't resolved, I'll likely jump ship with Netgear as a brand. I am tired of buying EXPENSIVE buggy routers. And I have been a loyal customer for over 25 years, installing many switches and routers for customers as well. Some of us expect better hardware for our money.
Is IPv6 enabled on the RS router?
Do you have native IPv6 support with the ISP?What driver version is being used on the Intel ethernet adapter?
Strictly IPv4 on both my network, and ISP. Driver is 2.1.5.7 dated as 9/3/25, as Windows sees it.
Has the newest trial version of beta FW been checked for this?
There is v1.0.8.10 available...
Will likely apply the update today. Timing was better after the holidays. I'll check back after a bit and let you know.
I posted this above....
- Boot up, as in power on Windows 11 14900K Desktop PC's, both hand built. Both have run on another Netgear router (AX120v2 with the overheating issue that was replaced by this RS700) without any DHCP issues. So The only real thing is that I do not have issues with DHCP issues from other equipment like my older Dell Gigabit switch can also assigns IP's to these 2 rigs with no problems. And yes, currently the DHCP side for that switch is disabled. I'm leaning toward the RS700 has issues with newer Intel LAN 226V chipset over a WIRED connection. You are over thinking this. Again, this issue appeared when this router was plugged into my network on week one, so IMO the rigs are not the issue as they work as expected on other network hardware. If I were to get a different router, I'd bet the problem would go away (AX120v2 worked, except it required an external fan to cool it). You'd think flagship products would actually be vetted before release. I'm sick of being a guinea pig for these companies buggy **bleep** routers that cost a fortune.
Do you have these PCs set for IP address reservation or are they set for Dynamic on the RS Router?
Are these the only devices exhibiting this issue with the Intel 226V chipset adapters installed.
What driver version are you using for the Intel Adapters?
Are these adapters built in to the motherboard or are they PCIe installable cards?
Which brand are these adapters if installable cards?
These PCs are not kept ON all the time and turned OFF?
Which LAN ports are you using on the RS router to connect these two PCs too?
As FURRYe38 asked, which specific Ethernet adapter is in these two PCs?
The internet seems to report that not all cards with the Intel 226-V chip perform the same. I could imagine a Netgear engineer remarking to his buddies, "Hey. I'm using an Intel 226-V on this RS700 and it works perfectly."
Any progress on this?
I woke my PC today and at the sign in screen the network icon seemed to take a few seconds to get going but it finally did and got connected. Noticed this with this PC. It's a older PC so not the fastest but it connected. I don't feel this is a RS issue. DHCP is working with my Intel I-226v adapter.
- WarmHelp_NTGRNETGEAR Expert
Replied with Logs and NIC data via PM. Thanks!
Thank you for reaching out, Overtkill
I have sent you a private message again. Please kindly check it when you have a moment.
Just curious if you have had any progress on this?
Have you given newer Intel adapter drivers a try?
I have not been able to reproduce this after installing newer Intel drivers.
Also there is a beta FW available as well for the RS router.
Seems like this issue between the RS and Intel i226-V adapter has been resolved.
