Overtkill
Dec 15, 2025Tutor
DHCP assignment issues on RS700 are not fixed
Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings. Thanks!!
- Jun 14, 2026
Issue resolved. BitDefender Security suite's firewall has an issue with detecting the network is a Home/Work network, and Public. Forced settings to Home/Work, and had to do this a few times on one rig, due to BD not saving the settings properly. One would think that they'd easily pull that information from Windows on install (c# System.Management "Network Category").
Additionally, it also has a "Stealth Mode" feature, that also has to be turned off.
This resolved the issue on all 3 machines.
I appreciate your help and time. And the same to WarmHelp_NTGR. :)
Thanks!
Dec 16, 2025Guru - Experienced User
Is IPv6 enabled on the RS router?
Do you have native IPv6 support with the ISP?
What driver version is being used on the Intel ethernet adapter?
Overtkill
Dec 16, 2025Tutor
Strictly IPv4 on both my network, and ISP. Driver is 2.1.5.7 dated as 9/3/25, as Windows sees it.
- FURRYe38Dec 16, 2025Guru - Experienced User
I've passed this to NG for review.
Does this mean the PC's did not get IP addresses assigned from the router when this happens?
Overtkill wrote:
Seems like a DHCP issue on the LAN side (Where's the lease time setting for this router??). Every week without fail, PC's will boot up with no Internet access through the RS700, requiring another reboot of each PC. Ethernet on my PC, which has seen this issue, is an Intel i226-V wired adapter on the motherboard. No issues with 2 older Netgear routers tried. RS700 has been updated to current firmware in October (1.0.9.16_2.0.106), reset and reconfigured several times as well. No changes. Adding machines (PC) to a reservation doesn't help. Devices on my LAN are mainly streaming, 2 phones and a tablet, 1 XBox (almost never used) and of course, several hand built PC's. Which are all on reservations at this point. No address conflicts exist at all. I am an admin BTW.
