Overtkill
Dec 15, 2025Tutor
DHCP assignment issues on RS700 are not fixed
Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings. Thanks!!
- Jun 14, 2026
Issue resolved. BitDefender Security suite's firewall has an issue with detecting the network is a Home/Work network, and Public. Forced settings to Home/Work, and had to do this a few times on one rig, due to BD not saving the settings properly. One would think that they'd easily pull that information from Windows on install (c# System.Management "Network Category").
Additionally, it also has a "Stealth Mode" feature, that also has to be turned off.
This resolved the issue on all 3 machines.
I appreciate your help and time. And the same to WarmHelp_NTGR. :)
Thanks!
Jan 07, 2026Guru - Experienced User
Has the newest trial version of beta FW been checked for this?
There is v1.0.8.10 available...
Overtkill wrote:Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings.
Overtkill
Jan 07, 2026Tutor
Will likely apply the update today. Timing was better after the holidays. I'll check back after a bit and let you know.
- FURRYe38Jan 07, 2026Guru - Experienced User
- OvertkillJan 12, 2026Tutor
So I flashed it the day of my last reply. Saturday, my wife's PC had the issue occur. In fact, for some reason, the issue with hers is always Saturday. Mine, Seems like hit and miss on that day. Both didn't have the issue with the previous router, the RAX120v2 with the overheat/dead fan issue that this one replaced.
- FURRYe38Jan 13, 2026Guru - Experienced User
So please give details on how you are setting up DHCP IP address assignments. I'll see if I can help test this as I recently got a RS700 to play with.
