Overtkill
Dec 15, 2025Tutor
DHCP assignment issues on RS700 are not fixed
Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings. Thanks!!
- Jun 14, 2026
Issue resolved. BitDefender Security suite's firewall has an issue with detecting the network is a Home/Work network, and Public. Forced settings to Home/Work, and had to do this a few times on one rig, due to BD not saving the settings properly. One would think that they'd easily pull that information from Windows on install (c# System.Management "Network Category").
Additionally, it also has a "Stealth Mode" feature, that also has to be turned off.
This resolved the issue on all 3 machines.
I appreciate your help and time. And the same to WarmHelp_NTGR. :)
Thanks!
Overtkill
Jan 07, 2026Tutor
Will likely apply the update today. Timing was better after the holidays. I'll check back after a bit and let you know.
Jan 07, 2026Guru - Experienced User
- OvertkillJan 12, 2026Tutor
So I flashed it the day of my last reply. Saturday, my wife's PC had the issue occur. In fact, for some reason, the issue with hers is always Saturday. Mine, Seems like hit and miss on that day. Both didn't have the issue with the previous router, the RAX120v2 with the overheat/dead fan issue that this one replaced.
- FURRYe38Jan 13, 2026Guru - Experienced User
So please give details on how you are setting up DHCP IP address assignments. I'll see if I can help test this as I recently got a RS700 to play with.
- FURRYe38Jan 14, 2026Guru - Experienced User
What is the brand and model# of the Wife PC?
Only happens with her PC?
I've set up some IP address reservations on two of my PCs, Xbox, Iphone and Android pad. Will see if my RS does anything to reproduce this.
- OvertkillJan 15, 2026Tutor
So, IP info:
Brands on affected PC's is MyOldAss Built i9 14900k's, wife's on an MSI Carbon z790, and mine is an Asus z790 Dark Hero Motherboard, both with the same intel 226v adapters, Both Win11 Pro PC's. both built Q4 2024. - I'd look between the RS700 and that specific LAN chipset.
Router lives at: 192.168.0.200
DHCP pool is: 192.168.0.20 - 192.168.0.99
I have the problem PC's assigned to reservations outside that pool at:
- My Rig: 192.168.0.100 - Wired.
- Samsung Phone: 192.168.0.101
- Samsung Tablet: 192.168.0.102
- Wife's PC is: 192.168.0.130 - Wired - Assigned recently for testing.
- Dell 2824 PowerConnect Switch: 192.168.0.205
Other items DHCP auto assigned are:
- a Dell network printer (192.168.0.24)
- 2 phones on wireless in the pool.
- 1 NVIDIA shield (wired, dhcp auto assigned addy)
- 1 Formular Android TV box.
- 1 Part time file server (Old intel 3930k workstation i210 adapter)
- 1 Part time Workstation (old 6900k workstation intel i217v adapter)
- 1 Part time Precision Workstation Laptop - Wireless most of the time.
- There are a few Netgear and Dell 8 port switches around the office and AV areas. Management features disabled.
Let me know what else I can tell you. I'd like to see better DHCP configuration settings in the router as well. Lease duration and such.
Will be running WireShark on Saturday morning.
