Overtkill
Dec 15, 2025Tutor
DHCP assignment issues on RS700 are not fixed
Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings. Thanks!!
- Jun 14, 2026
Issue resolved. BitDefender Security suite's firewall has an issue with detecting the network is a Home/Work network, and Public. Forced settings to Home/Work, and had to do this a few times on one rig, due to BD not saving the settings properly. One would think that they'd easily pull that information from Windows on install (c# System.Management "Network Category").
Additionally, it also has a "Stealth Mode" feature, that also has to be turned off.
This resolved the issue on all 3 machines.
I appreciate your help and time. And the same to WarmHelp_NTGR. :)
Thanks!
WarmHelp_NTGR
Mar 05, 2026NETGEAR Expert
Overtkill
Mar 14, 2026Tutor
Replied with Logs and NIC data via PM. Thanks!
- WarmHelp_NTGRMar 15, 2026NETGEAR Expert
Thank you for reaching out, Overtkill
I have sent you a private message again. Please kindly check it when you have a moment.
