DeeDee123's avatar
Jan 03, 2020
Devices on VLAN do not get IP from DHCP
Dear NETGEAR community,   I have been banging my head for a long time now and seek advice from you folks that are much more experienced than me. Please if you need additional info or clarification,...
  • DeeDee123's avatar
    DeeDee123
    Jan 18, 2020
    Hi DaneA,
    Thanks for getting back to me! I think i found the issue to my problem. It was my DHCP server now being able to route back to my pfsense box because I removed the default gateway from the dhcp server's nic interface.
    I think I should be able to get it working now!
    Thanks agani!
ProSupport for Business
