DeeDee123
Jan 03, 2020Tutor
Devices on VLAN do not get IP from DHCP
Dear NETGEAR community, I have been banging my head for a long time now and seek advice from you folks that are much more experienced than me. Please if you need additional info or clarification,...
- Jan 18, 2020
Hi DaneA,
Thanks for getting back to me! I think i found the issue to my problem. It was my DHCP server now being able to route back to my pfsense box because I removed the default gateway from the dhcp server's nic interface.
I think I should be able to get it working now!
Thanks agani!
DaneA
Jan 15, 2020NETGEAR Employee Retired
Let us try the following below:
Does your pfSense router supports DHCP L2 Relay Agent? If yes, then you will need to enable and configure it on the pfSense router.
On the XS716T web-GUI, go to System > Services > DHCP L2 Relay > DHCP L2 Relay Global Configuration. Select Enable and click Apply.
Go to System > Services > DHCP L2 Relay > DHCP L2 Relay Interface Configuration. Select the port members of VLAN 2. Then on both Admin Mode menu and 82 Option Trust Mode menu, select the port members of VLAN 2 and click Apply.
Make sure that ports 2 and 12 are set as tagged ports on all VLANs with PVID = 1. Port 13 should be set as untagged port to VLAN 2 with a PVID of 2.
DaneA
NETGEAR Community Team
DeeDee123
Jan 18, 2020Tutor
Hi DaneA,
Thanks agani!
