robfantini
Jun 06, 2018Aspirant
dhcp snooping troubleshooting
Hello
I am in the process of trying to migrate from a gsm7353s [ m4100] to this new 10G switch.
dhcp snooping has been turned on.
however clients are not getting dhcp.
- Jun 09, 2018
it looks like this switch is not a replacement for our GSM7352Sv2 48 .
our current switch has a lot more capability like UDP Relay and being able to set up at UDP Relay Global Configuration - our dhcp servers to use for udp relay.
thanks anyway for the help!
JohnC_V
Jun 07, 2018NETGEAR Employee Retired
Hi robfantini,
May I know if you are setting up trunks or static routes?
Hope this article may lead you to the right direction. How do I configure Dynamic Host Configuration Protocol (DHCP) snooping using the web interface on my managed switch?
- robfantiniJun 08, 2018Aspirant
static routes are set on pfsense in one line:
<staticroutes>
<route> <network>10.1.0.0/16</network> <gateway>GW_LAN</gateway> <descr></descr> </route>
</staticroutes>
GW_LAN goes to 10.1.0.1 . which is vlan 2 on the switch.
vlan 37 goes to the switch with desktop computers and office phones. that is a M4100-50G-POE.
the lag connecting the switches is set to vlan 37U , pvid 37 .
the DHCP server runs on a Proxmox server.
the port is U10 , T3 . proxmox host is on vlan 10 , the virtualized dhcp server uses vlan 3 3.
I can supply more info if needed.
note the programming for vlans and pvid is identical to the production switch that just works.
I'll be on site tomorrow working on the switch, will read the link you sent and try some changes.
let me know if i can supply more info to make our setup clearer.
thanks for the help!
Rob
- robfantiniJun 09, 2018Aspirant
