nayan_n002's avatar
nayan_n002
Follower
Sep 13, 2019
DNS setup
I want to buy a netgear nighthawk s8000 device.My ISP serve me a static ip and it fixed Ip address, Net mask, Get way, and two fixed DNS server. Can i set up net mask,get way, DNS on netgear nighthawk s8000 switch?
  • Hi nayan_n002,
    Welcome to our community! :)
    You may need a router and not a switch in order for you to set up your static IP coming from your ISP. The switch is only an additional port from your router.
    John
    NETGEAR Community Team
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Apps and Services. (This is easily done, given Netgear's impenetrable community structure.)
    You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
    Switches - NETGEAR Communities
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi nayan_n002,
    John
ProSupport for Business
