Nazgand's avatar
Nazgand
Router DNS settings do nothing
Being able to set the default DNS for everyone in the house is extremely important.
I set up my router to use Quad9 as the primary DNS; the setting does nothing.
https://on.quad9.net/ says `No, you are NOT using quad9.`
Unfortunately, I am not able to install better firmware, which is at `V1.0.6.16`.
Status: `No new firmware available`
Router type: Netgear Nighthawk BE9200 WiFi 7 Router (RS280)
ADVANCED > Setup > Internet Setup > IPv4
Domain Name Server (DNS) Address
[Selected] Use These DNS Servers
Primary DNS:
9. 9. 9. 9
Secondary DNS:
8. 8. 8. 8
Third DNS:
1. 1. 1. 1
ADVANCED > Setup > Internet Setup > IPv6
IPv6 Domain Name Server (DNS) Address
Primary DNS:
2620:fe:0:0:0:0:0:9
Secondary DNS:
2001:4860:4860:0:0:0:0:8888
  • The router was not the problem.
    `Google Chrome > ⋮ > ⚙ Settings > 🛡 Privacy and security > 🔒 Security > Select DNS provider` needs to be set to `OS default (when available)`.
    • StephenB's avatar
      Agreed.  Chrome, FireFox, Safari, and Edge all can be set up to use different DNS from the OS (and therefore not the same as the router DNS config).
