Nazgand
Feb 17, 2026Aspirant
Router DNS settings do nothing
Being able to set the default DNS for everyone in the house is extremely important. I set up my router to use Quad9 as the primary DNS; the setting does nothing. https://on.quad9.net/ says `No, you...
- Feb 17, 2026
The router was not the problem.
`Google Chrome > ⋮ > ⚙ Settings > 🛡 Privacy and security > 🔒 Security > Select DNS provider` needs to be set to `OS default (when available)`.
Nazgand
Feb 18, 2026Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
