Nazgand
Feb 17, 2026Aspirant
Router DNS settings do nothing
Being able to set the default DNS for everyone in the house is extremely important. I set up my router to use Quad9 as the primary DNS; the setting does nothing. https://on.quad9.net/ says `No, you...
- Feb 17, 2026
The router was not the problem.
`Google Chrome > ⋮ > ⚙ Settings > 🛡 Privacy and security > 🔒 Security > Select DNS provider` needs to be set to `OS default (when available)`.
Nazgand
Feb 19, 2026Guru - Experienced User
Nazgand wrote:The router was not the problem.
Agreed. Chrome, FireFox, Safari, and Edge all can be set up to use different DNS from the OS (and therefore not the same as the router DNS config).
