jerry2096
Feb 27, 2022Aspirant
Does gs switch support trunk port
As subject - does it support Trunk port? If not, which Netgear model support it? For home lab. thanks
schumaku
Feb 27, 2022Guru - Experienced User
Yes, of course. The VLAN must be defined first, then you can e.g. create a trunk port (similar also a trunk LAG) for participating untagged in only one VLAN (VLAN x [u]ntagged, PVID 1, and multiple tagged VLAN (VLAN y [t]agged, VLAN z [t]agged.
