winc's avatar
winc
Guide
Apr 20, 2023
Switch to do VLANs and VLAN trunking
What is the smallest Netgear switch that will handle VLANs as well as VLAN trunkling.  TIA.
  • Hi winc ,
    You can opt for the below switch models for your mentioned specifications
    16-Port Gigabit Ethernet PoE+ Smart Switch w/ optional Cloud/Remote Management and 2 SFP ports (180W)
    16-Port Gigabit Ethernet PoE+ Smart Switch w/ optional Cloud/Remote Management and 2 SFP Ports (300W)
    Have a lovely day,
    Anisha A
    Netgear Team
    If your issue is resolved please close the thread by clicking "Accept as solution".
  • schumaku's avatar
    schumaku
    The question is what small means for you....
    • number of ports?
    • port speed?
    • static or LACP LAG?
    • Configurable or smart management type or cloud managed?
    • PoE support?
    Switches coming into my mind are
    • GS305E
    • GS308E
    • GS308T
    • winc's avatar
      winc
      Guide
      Thanks Schumaku.
      5 ports would be adequate.
      10/100/1000 port speed will work as long as it auto-negotiates.
      LACP LAG preferred.
      Configurable/Smart managed preferred.
      PoE preferred.
      Do you know if Netgear has a chart/matrix that compares/shows the capabilities of their switches?
      • AnishaA's avatar
        AnishaA
        NETGEAR Employee Retired
        Hi winc ,
        Have a lovely day,
        Anisha A
        Netgear Team
ProSupport for Business
