Retired_Member
Feb 22, 2022GS105PE VLAN trunking not working
I’m trying to set up a GS105PE in the garage. I intend to add an Orbi Pro Wifi6 satellite there and we already have a POE camera in position.
The GS105PE connects to a GS324TP switch, which also powers it.
I have three VLANs set up: IDs 1,20,30 and 40.
The GS105 has port 5 as its uplink. It’s connected to port 17 on the GS324.
GS324 port config:
VLAN 1 untagged
VLANs 10-40: tagged
GS105: same configuration for the uplink port. The result: the switch is no longer accessible after committing the setup and rebooting. According to the insight app, it gets an apparently self-assigned IP in the .66 range. That range doesn’t exist on the Orbi pro and has never been configured.
If tried all kinds of other combinations of tagged and untagged VLANs on the GS105s uplink port - not a chance. Have to reset the GS105 after every attempt.
What am I overlooking here?
GS324 port config:
VLAN 1 untagged
VLANs 10-40: tagged
- Retired_MemberFeb 23, 2022Thanks, got it working! Tagging the uplink for VLAN ID 1 didn’t work, but setting the IP to manual did the trick. I’d used a reserved IP before and for some reason that messed things up
- Retired_Member
Change VLAN1 to tagged as well. BTW, I always set up static IP addresses (VLAN1 subnet) on my switches or at least do DHCP reservations for them.
- Retired_MemberThanks, got it working! Tagging the uplink for VLAN ID 1 didn’t work, but setting the IP to manual did the trick. I’d used a reserved IP before and for some reason that messed things up
The GS105PE connects to a GS324TP switch, which also powers it.Is this an extension from a wired backhaul?
GS324 port config:
VLAN 1 untagged
VLANs 10-40: tagged
GS105: same configuration for the uplink port.Assuming the PVID on the ports used for the trunk are set to PVID 1 - this makes perfect sense.
The Retired_Member proposal also tagging the VLAN 1 on the trunk is philosophical - untagged it is much easier to just connect a system to access the VLAN 1.
According to the insight app, it gets an apparently self-assigned IP in the .66 range. That range doesn’t exist on the Orbi pro and has never been configured.All the Plus switches (except a few models which allow the config of a real management VLAN) can pick-up IP configs by DHCP from any connected VLAN.
Some confusion what is a "self-assigned IP" - that would be some ZeroConf 169.254.x.x/16 address. However, the Netgear switches don't support self-assigning address spaces. Remains the question what address that ".66" rage should reflect? Some public IP leaking over for example?
- Retired_MemberYes it is (an extension from a wired backhaul).
I got the setup working using a fixed IP. The DHCP reservation was ignored for some reason once the uplink port was tagged for the 20-40 VLAN IDs. Now I’m trying to figure out where that .66 network is coming from. Our WAN hookup is a shared medium (cable internet), so I guess it’s theoretically possible this is bleeding in. But tbh I don’t like the idea of that.
