Retired_Member
Feb 22, 2022GS105PE VLAN trunking not working
I’m trying to set up a GS105PE in the garage. I intend to add an Orbi Pro Wifi6 satellite there and we already have a POE camera in position. The GS105PE connects to a GS324TP switch, which also po...
- Retired_MemberFeb 23, 2022Thanks, got it working! Tagging the uplink for VLAN ID 1 didn’t work, but setting the IP to manual did the trick. I’d used a reserved IP before and for some reason that messed things up
Retired_Member
Feb 22, 2022Change VLAN1 to tagged as well. BTW, I always set up static IP addresses (VLAN1 subnet) on my switches or at least do DHCP reservations for them.
Retired_Member
