tantony's avatar
tantony
Luminary
Jul 15, 2019
Trunk Vs. Untagged multiple VLANs
Sorry if I'm in the wrong forum.
Let's say I have 2 VLANs.  VLAN 5 = IT, VLAN 10 = Admin
What's the difference between making a port trunk (T), then adding both VLANs, and making a port untagged (U), and adding both VLANs.  They do the same thing correct?  I can't seem to figure out what difference it makes.  I know trunk (T) can carry multiple VLANs, but if I untag (U) a port and make it members of both VLANs, it does the same thing correct?
For example:
Port 23:
VLANs 5,10 both (T), PVID 5
Port 23:
VLANs 5,10 both (U), PVID 5
They both do the same thing?
  • tantony wrote:
    Port 23:
    Port 23:
    No.
    The first is a direct "trunk" type port carrying multiple tagged VLANs.
    The second one is a config you should avoid in general - as it does create some asymmetrical VLAN ... while the VLAN ID 5 (with PVID 5) will work for incoming and outgoing traffic, there will be also VLAN ID 10 traffic flowing off the switch, but not back to that VLAN. Simple: You can't have more than one VLAN untagged on a port. Anything else is of theoretical and academic value only.
  • schumaku's avatar
    schumaku
    tantony wrote:
    Port 23:
    Port 23:
    No.
    • tantony's avatar
      tantony
      Luminary
      schumaku
      Thank you.  So just to make sure I understand it clearly, method 2, where I made port 23 untagged (U) with both VLANs, might or might not work depending on the circumstances, but is not a good practice.
      • schumaku's avatar
        schumaku
        Take the second one as an academical solution only. For us, the aim of VLANs is to create independent broadcast domains - with the second config you mix things up.
    • nagraiv's avatar
      nagraiv
      I was actually wondering why my Netgear switch allows multiple untagged VLANs on the same port.
      What is the point of that?
      I never do that, I only just have on untagged VLAN per port (and I always forget that I also need to set the port's PVID to that VLAN... my other switches only allow me to set 1 untagged VLAN and that is the PVID, with Netgear I have to do both since they allow multiple untagged VLANs).
