MattWard
Oct 14, 2023Follower
Does GS316EPP SFP port support 2.5G?
Got two of the GS316EPP and was hoping to connect them together with a 2.5G SFP transceiver using cat6 ethernet (less that 30m apart). Got a pair of SFP2.5G transceivers and they don't work. Making m...
schumaku
Oct 14, 2023Guru - Experienced User
Both the GS316EP and GS316EPP models are - including the SFP ports - pure Gigabit-Ethernet only devices.
Only these SFP modules are supported:
AGM731F SFP Transceiver 1000BASE-SX (Short range, multimode)
AGM732F SFP Transceiver 1000BASE-LX (Long range, single mode)
AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC
So your initial assumptions are correct.
