CE2019
Nov 04, 2019Aspirant
Does the GS748T supports SFP+ 10GB modules?
Hello
Does switch GS748T supports SFP+ 10GB modules?
We found some info, but we want to make sure before we buy anything.
Fits into SFP+ interfaces of M4200, M4300, M5300, M6100, M7100 and...
- Nov 04, 2019
Hi, thank you for your message
No, SFP+ modules won't work because the GS748T has SFP ports, not SFP+ ports. As such, the GS748T can only connect 1G SFP modules, not 10G SFP+ modules.
I hope his helps,
Regards
LaurentMa
Nov 04, 2019NETGEAR Expert
I hope his helps,
Regards
CE2019
Ok, thanks for the quick reply!
