ChayneChiles
May 23, 2023Aspirant
Dual XS728T Setup with Proxied Gateway's
Good afternoon all
I come to you seeking advice. ( I asked for advice recently, But i did not knowall the facts at the time
and the solution given would not suite my setup)
I have been tasked with settng up the two new XS728T Switches we have.
They will replace 3 GS724T
We have a a Proxied Virtual Router Setup from our ISP
It's purpose is to manage when and if we have a fault on our main internet Line
Basically like this
Virtual IP = 192.168.0.1(main gateway)
Router 1 = 192.168.0.251
router 2 = 192.168.0.252
The Virtual IP will then direct traffic to the current main port for internet use.
Now onto my issue
Our intention was to have one router in switch A and another in Switch B
This would give us redundancy if a switch goes down.
I have setup two Vlans
One unfiltered with a direct connection to the internet(this one can see both Router IP's)
And a second filtered Network (this traffice runs from switch A into DDOS, From DDOS into Switch B VLAN 2)
How can i get VLAN 2 to see the Second Router port plugged into switch B?
- latestgbappsAspirant
I also want to know solution of this problem
What is the point for this request? The XS728T is in no aspect a router, and even less a HA system.
Wild guess, your router 1 + 2 does have at least two free ports available, this is where the XS728T can be connected to offer an Internet uplink, it will serve as the default gateway .1 - nothing difficult or complex.
No idea what the intention for multiple VLANs for the Internet connection should be, what for you plan to create additional VLANs for Internet purpose.
