tonynsx
Apr 23, 2019Luminary
Dummy switch connected to smart switches LLDP
I'm going to have a non Netgear dummy switch connected to a Netgear smart switch which will containg LLDP for VoIP. If I connect a VoIP phone to the dummy switch, would it get the LLDP from the smar...
- Apr 23, 2019
Of course not. Re-think what LLDP does mean ... Link Layer ... the link - that's where the cable or fiber is directly connected to, that's the thing between two ports.
tonynsx
Do they make any 5 port managed LLDP switches? I don't have the need for a 16 or 24 port switch.
- schumakuApr 23, 2019Guru - Experienced User
Be exact what you need - only IEEE 802.1ab LLDP, the more complex LLDP-MED, Auto Voice VLAN...?
AFAIK there are Smart Managed Pro switches supporting LLDP-MED starting from eight ports (like the GS108Tv3, GS110TPv3, GS308T, GS310TP, ...).- tonynsxApr 23, 2019Luminary
LLDP-MED, Auto voice VLAN. The GS108Tv2 does that
