Prodokomoni
May 21, 2024Aspirant
Dynamic VLAN assignment doesn't work GS724Tv4
Hello, I have a problem with dynamic VLAN assignment with MAC Based port setting. Switch GS724Tv4. There is Initialize status without log entries (Informational) on port, no reporting to RADIUS se...
schumaku
May 23, 2024Guru - Experienced User
The VLAN 60 is defined in Switching -> VLAN as a static VLAN?
- ProdokomoniMay 30, 2024Aspirant
Hello,
yes, VLAN 60 is defined manually in configuration.
It looks like switch doesn't communicate with RADIUS server, doesn't get any reply and put port to defined guest VLAN 60.
- schumakuMay 30, 2024Guru - Experienced User
How is RADIUS involved here, this is pure local isn't it?
