DougShuffield
Mar 08, 2019Tutor
Enable / Disable POE per port via ssh / telnet
I would like to know the command sequence to enable / disable POE on a port by port basis. In the user interface this is the admin mode column. I have not been able to find a full description of th...
- Mar 08, 2019
Instead of using the (unsupported, well possible incomplete, ...) CLI access use SNMP -> https://community.netgear.com/t5/Smart-Plus-Click-Switches/Switch-GS728TP-POE-Admin-enable-disable-via-SNMP/m-p/1574183/highlight/true#M9657
The GS727TP is a Smart Managed Pro switch, not a Managed Switch -> Smart / Plus / Click Switches (easy to overlook on the brilliantly bad community structure ChristineT Christian_R )
schumaku
Mar 08, 2019Guru - Experienced User
