RonV42
Dec 20, 2016Luminary
QOS on Orbi is it enabled or disabled?
Ok so I am on the QOS page and there is nothing to say it's enabled or disabled. Ran the speed test on the page and it shows the resutls but no indication of QOS is turned on or off. We need a checkbox or somthing here for enableing and disabling.
- Retired_MemberDec 26, 2016
Worked. The HTML has to be changed to HTM.
on my way to buy an Orbi. Will watch this thread. Have you tried another browser? Looks like your missing alot of options as per my R7000
- RonV42Luminary
Yes I logged into it with 4 different browsers:
- EDGE
- IE11
- Firefox
- Chrome
Same page on all 4...not a browser issue.
when you run the speed test it asks you if you want to set the speed test as the qos on the latest fw , this is then used as auto qos
- RonV42Luminary
It never asks to question to use it just displays the results on the page...I assume it's using it but again there needs to a way to turn off and on.
i think at this stage you would have to factory reset
setting the max qos is a good thing anyway as it stops any one device from hoging the whole bandwidth
- Agreed that is crazy.
the qos is still a work in progress , in time it will be like it is on the r8500 etc , just in baby steps
- Dan_HApprentice
Hey peteytesting, what kind of throughput can we expect with QoS enabled?
