varo26278
Jul 09, 2021Aspirant
Exchange multicast packets between two managed switches
Firstly, the model that I set above is not the one that I'm ussing. It doesn't allow to type GS108Tv3. This is the model that I'm using. I have two GS108Tv3 switches. According to technical speci...
schumaku
Jul 09, 2021Guru - Experienced User
Nothing you can do ref. Multicast routing on these tiny switches. You need some external router (or some Linux system) assistance where you can config some Multicast routing done.
varo26278
For instance, if I use the netgear model R6120 router, is it enough?
- schumakuJul 09, 2021Guru - Experienced User
Negative. To my knowledge, these routers only support one LAN subnet, and (like virtually all Netgear consumer routers) there is no Multicast routing and forwarding capability.
Unfortunately, not even the Netgear BR200/500 do. The feature was just recently added to some Orbi Pro AX when I have it right.
