KrustyK
Mar 12, 2018Aspirant
Switch drop PTP multicast
Hi ,
I try to configure a m4300 8x8f switch with three connected devices, a PTP source and two PTP receiver. But i have a problem, the switch seems to drop every ptp multicast packet. I have activated the general routing, routing on every interface, pim dense mode, igmp. In addition i can see the ptp multicast group on "routing/multicast/mroute table" with the right interface/ip source. Any advises will be welcome.
Best regards
Problem fixed, IGMP on master clock was is in version 2 but IGMP on netgear switch was is in version 3. Downgrade to version 2 and all works fine.
- Anonymous
Hi KrustyK
Welcome to the community!
For further analysis, Could you please provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
Hope it helps!
EricZ
NETGEAR employe- KrustyKAspirant
Thanks for the quick reply, I've email the support (to your attention) with the appropriate files.
- Anonymous
Hi KrustyK,
Got the tech-support file from you. Thanks again!
Looks like the configuration is correct!
Could you please run CLI command on the switch as below:
1. show ip mroute summary
2. show ip igmp groups x/x/x(the PTP receiver port number)
3. show interface counters(do 'clear counters all' first)
BTW: I try on local switch, it's success. DUT can forward the multicast packet success.
(M4300) #show ip mroute summary
Multicast route table summary
Incoming Outgoing
Source IP Group IP Protocol Interface Interface List
192.168.2.1 239.1.1.1 PIMDM 1/5/1 1/11/1 1/11/2
(M4300) #show ip igmp groups 1/11/1
IP Address..................................... 192.168.4.2
Subnet Mask.................................... 255.255.255.0
Interface Mode................................. Enabled
Querier Status................................. Querier
Multicast Group IP............................. 239.1.1.1
(M4300) #show ip igmp groups 1/11/2
IP Address..................................... 192.168.5.2
(M4300) #
- KrustyKAspirant
Retired_Member
I have try:
set igmp
set igmp header-validation
set igmp querier
set igmp proxy-querier
But PTP multicast traffic is still dropped.
So, this is the results of the commands:
Incoming Outgoing
192.168.4.1 224.0.1.129 PIMDM 1/0/9
2. i. show ip igmp groups 1/0/11
IP Address..................................... 192.168.2.2
2. ii. show ip igmp groups 1/0/13
Port InOctets InUcastPkts InMcastPkts InBcastPkts InDropPkts
1/0/1 0 0 0 0 0
1/0/2 0 0 0 0 0
1/0/3 0 0 0 0 0
1/0/4 0 0 0 0 0
1/0/5 0 0 0 0 0
1/0/6 0 0 0 0 0
1/0/7 0 0 0 0 0
1/0/8 0 0 0 0 0
1/0/9 800 0 8 0 0
1/0/10 0 0 0 0 0
1/0/11 3243 46 0 0 0
1/0/12 0 0 0 0 0
1/0/13 0 0 0 0 0
1/0/14 0 0 0 0 0
1/0/15 0 0 0 0 0
1/0/16 0 0 0 0 0 - KrustyKAspirant
Retired_Member
I have try:
set igmp
set igmp querier
Incoming Outgoing
1/0/1 0 0 0 0 0
1/0/2 0 0 0 0 0
1/0/3 0 0 0 0 0
1/0/4 0 0 0 0 0
1/0/5 0 0 0 0 0
1/0/6 0 0 0 0 0
1/0/7 0 0 0 0 0
1/0/8 0 0 0 0 0
1/0/9 800 0 8 0 0
1/0/10 0 0 0 0 0
1/0/12 0 0 0 0 0
1/0/13 0 0 0 0 0
1/0/14 0 0 0 0 0
1/0/15 0 0 0 0 0
1/0/16 0 0 0 0 0
