spuch
Jan 27, 2021Guide
Firmware update 2.6.0.48 blocks access to the webinteface outside the own subnet
Hi Techs, today I updated the firmware on one of our GS116Ev2 from 2.6.0.43 to 2.6.0.48 via webinterface from a remote host which is connected via OpenVPN to network of switch. While the update coul...
schumaku
Jan 29, 2021Guru - Experienced User
Reads like the default gateway and/or subnet mask isn't properly handled on the Smart Managed Plus switch microcontroller, or there is a problem with the ARP resolution.
- spuchJan 29, 2021Guide
In the German community forum there is a thread with a note that the engineering department has confirmed some similar problems with FW version V2.06.14 which is for GS108Ev3. Maybe the problems are related or similar therefor I link it here in this thread. The GUI is not available anymore although the IP Adress can be reached. The problem is in both german and English firmware.
Further more there is a second thread explicitly related to the GS116Ev2 firmware 2.6.0.48. In that case the connection doesn't work with the Prosafe Plus Utility and a downgrade to previous firmware fixed the problem.
