supertramp4
Jul 05, 2016Aspirant
FS728 - "current firmware" rev is older than "previous versions" ?
Hi,
Can anyone advise if the "Current Firmware" which is listed as actually 5.0.2.33 is older than the "Previous Firmware" which shows a later revision of 5.0.2.39
Also there are no Release notes for 5.0.2.33, so just trying to understand which version i should be using.
Physically i have 5.02.39 installed on my switch. by installing 5.0.2.33 am i upgrading, or downgrading ?
http://www.netgear.com/support/product/FS728TPv2.aspx?cid=wmt_netgear_referral?cid=wmt_netgear_organic#Firmware Version 5.0.2.26?cid=wmt_netgear_referral?cid=wmt_netgear_organic
Many Thanks
Chris
Hi supertramp4,
I believe that the support page for the FS728TPv2 has been corrected already. Kindly check it here.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi supertramp4,
Welcome to the community! :)
I have already inquired about this. Once I get a response, I will post it here on this forum thread.
DaneA
