supertramp4
Sep 21, 2016Aspirant
FS728 Firmware vunerability 5.2.0.39
Hi, Over 6 months ago, i raised a support case NETGEAR Support Case #26454088, highlighting a security issue with the product, and i am shocked, that still there are no firmware updates available to...
- Sep 21, 2016
Hi supertramp4,
I believe there is already a beta firmware for the Vulnerability CVE-2013-4775 just recently. You may want to give it a try and it might help. Since your support warranty has expired, you want to try the NETGEAR Chat Support here and ask for assistance.
DaneA
NETGEAR Community Team
DaneA
Sep 25, 2016NETGEAR Employee Retired
Hi supertramp4,
I just want to follow-up on this. Were you able to ask assistance from the NETGEAR Chat Support about your concern?
DaneA
- supertramp4Sep 28, 2016Aspirant
Hi DaneA,
Yes, I was able to contact support who provided Beta Firmware 5.0.2.44. A Re-scan of our network with our vunerability scanner has confirmed the security problem is resolved.
Thanks again for your assistance
Chris
- DaneASep 28, 2016NETGEAR Employee Retired
Hi supertramp4,
That's great! :) I'm happy to know that NETGEAR Support was able to help you and the problem is now resolved. :D
Since your concern has been resolved, kindly mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
