steven42
Nov 30, 2020Aspirant
GC110 Switch - L2TP/IPSec VPN to NAS
I have a Synology NAS which I've been able to access remotely via VPN L2TP/IPSec, I was on an unmanaged switch before but upgraded to the GC110 so I can do link aggregation to improve my bandwidth to...
schumaku
Nov 30, 2020Guru - Experienced User
steven42 wrote:I was able to successfully configure the link aggregation without changing any of my network settings, so it should have been a pure swap of hardware (unmanaged swich to managed switch) but I was unable to establish a VPN connection with the new managed switch.
Something sounds wrong here. You have to change the config on both the NAS and the switch e.g. to a LACP LAG config. Doing so might change the interface config on the Syno VPN config - so some adjustment might be required.
steven42
I did configure the LAG settings on the switch and the link aggregation setting on the Synology NAS, I double checked that and I'm certain I have those setting correct, I was able to access the NAS locally, and I did have increased bandwith to my NAS. Its only when trying to establish a VPN connection did it stall out. When I tried to connect via VPN from my windows laptop, it said something like there was a security layer that prevented the connection, which is why I'm wondering if, like my router, I have to open up ports etc. I'm sorry, I don't know if this switch acts like a router and have to configure firewall settings like a router
- schumakuDec 01, 2020Guru - Experienced User
No, the switch is by default fully L2 transparent. Review the VPN config on the NAS - it must use a different interface (the LAG one!) instead of a single physical ETH.
- Jun 06, 2019Retired_Member
